ProjeQtOr free project management software - visual problem - ProjeQtOr
visual problem
29 Mar 2013 09:32 #1 by DjackJack
visual problem was created by DjackJack
I created a table with 2 date fields (start date and end date) and I would like to see these two fields replaced a visual point of view by one to select a month but it is not in the database data. How to do that?
29 Mar 2013 09:37 #2 by babynus
Replied by babynus on topic Re: visual problem
I don't understand what you try to do. :unsure:
Could you explain a bit further ?
01 Apr 2013 00:19 #3 by DjackJack
Replied by DjackJack on topic Re: visual problem
I created a new menu to insert some statistics. For the moment these statistics are monthly, but later they will be quarterly, annual or dates to dates. This is why I immediately creates a table with 2 date fields (start date and end date) and fields useful for managing my statistics. Following tools facilitating the design that you have already developed, I created an object in the model folder with the same fields in the database données.Il behaves like the object "project" and so when I click about where to create a new item, I end up with all the fields specified in the object and in this base.
This is where my problem comes because today I find myself with the start date and end date on the present me to create this new object, and I will wish for the moment he could not see these two date fields but rather a field just to choose a number between 1 and 12 that corresponds to a month and I would do the background processing to select the date at the beginning and end of the month. How to do that?
01 Apr 2013 00:46 #4 by babynus
Just set the dates as hidden fields (or readonly) and set new field as scpecific ones : name starts with $_spe_ and definition is in drawSpecificItem().
You can see examples in some objects, for instance in Project or WorkElement.
