ProjeQtOr free project management software - Problème Installation et Configuration Project'or ria avec Easyphp Portable sur Clé USB - ProjeQtOr
09 Apr 2013 11:03 #1 by luckydigit
I am a new user of project'or ria and I try to install it on a USB key with Easyphp Portable.
I pass to start project'or ria application and I see the configuration page.
I delete the mysql password and I click on OK.
Then it says : "parameters are saved" and a button continue appears.
I click on the continue button, and then I have a FATAL ERROR something like Maximum Nesting over 100 in SqlElement.php file in line 1329.
I don't know if this FATAL error can make a bug on the application but I refresh my page and I have the user/password page that appears.
Then, I try to enter admin/admin and click on OK and then, I have the message : wrong parameters.
I don't understand why it doesn't work to use project'or ria on usb key with easyphp portable.
In parallel, I try other applications with easyphp portable and they works.
In parallel, I try to use on a PC project'or ria with easyphp and it works.
But I need to use it with USB key.
Could you help me.
Thank you in advance,
09 Apr 2013 11:21 #2 by luckydigit
I would like to add one information to progress on my matter.
With PhpMyAdmin, I saw that I had a projectorria database in easyphp. so I delete it.
And I redo the configuration of projectorria with the parameters.php file.
Then, I click on OK and a message appeared : database created, parameters saved.
Then I click on Continue and then I see the user/password page.
I entered admin/admin and then the spinner appears and after several minutes, it has not desappeared.
Is it normal. Did I make something wrong ?
Thank you in advance for your reply.
09 Apr 2013 13:58 #3 by luckydigit
I finally passed to connect to project'or ria.
The matter was that :
- My first connection had been interrupted and then when I tried to connect to the database it didn't work because the user/password wasn't recognized.
- By USB, on my computer it is very long to initialize the database
So, after having delete and create a new database and ensure no interruption during the first connection, I can access to the application.
And it is not so long between to actions even on USB key.
Sorry for my previous message.
Subject Closed on my side.
