ProjeQtOr free project management software - print function in 'Real work allocation' page - ProjeQtOr
01 Jun 2011 11:55 #1 by Guest
I have a question about the print function.
In the Real work allocation page, when I press the print button,
the print dialog shows up, but no data appears.
Also the waiting circle keeps showing on the screen.
Is it a bug?
I checked with your demo site and can't get the data on the print screen, either.
Could you check?
Thanks a lot.
Best Regards,
Selina
02 Jun 2011 16:22 #2 by babynus
Printing works for me, on Demo or other locally installed versions.
Can you chek for Javascript errors ?
Which browser are you using ? Wich version of brother ?
Which version of Project'Or RIA ?
Regards.
Babynus.
03 Jun 2011 02:54 #3 by Guest
I usually use firefox to open the page.
I just tried to open by IE 7, still the same. But found there's an exclamation mark shown at the bottom left of the status bar.
I clicked on it.
It shows
page has problem, can't display correctly
line: 235
character: 4
mistake: 'dojo.byId(....)' is null or not a object
code: 0
URL: projectorria.toolware.fr/demo/view/main.php
Which javascript in which file would cause the problem?
I don't know why yours is ok, mine just can't work?
Please help.
Thanks a lot.
Best Regards,
Selina
03 Jun 2011 02:57 #4 by Guest
My version is v1.5.5
firefox version is 3.6.16
Selina wrote: Hi,
I clicked on it.
It shows
line: 235
character: 4
code: 0
Please help.
Thanks a lot.
Best Regards,
Selina
03 Jun 2011 10:24 #5 by babynus
Strange you get such an error.
But this is a clue.
Can you get the full error within Firefox : [CTRL]+[SHIFT]+J to open the error console.
Babynus.
07 Jun 2011 03:12 #6 by Guest
I got the message 'dojo.byId("outMode") is null
projectorria.toolware.fr/demo/view/projectorDialog.js' line 234
Please help.
Best Regards,
Selina
