ProjeQtOr free project management software - Project not visible in "Projects" view for Project Leader role after project status = closed - ProjeQtOr
13 Apr 2013 20:11 #1 by FEtchevarren
Even though I check the "show closed items" checkbox its not visible: thats happens with the Project Leader role.
If I do the same with an admin role, it works: I didnt change any default permissions, is this normal?
14 Apr 2013 01:31 #2 by babynus
Admin sees all projects.
Project Leader sees only projects he is affected to, with not closed affectation.
Since V3.2.0, following #1013 request, when a projet is closed, all the affectations to this projet are also closed.
So Project Leader will not be able to see closed projects.
