ProjeQtOr free project management software - dbVersion'problem - ProjeQtOr
dbVersion'problem
24 May 2013 15:13 #1 by DjackJack
dbVersion'problem was created by DjackJack
I try to implement new functionality for projector'RIA.
And to avoid having problems with your update and I have mine set up an additional basic version (dbVersionXXXx) and therefore related files were modified versions (model / parameter.php, db / maintenance.php, tool / projector, etc. ...).
Normally, all works correctly. Only during a period of inactivity too long in the database the password DBVersion V3.3.2 to V3.2.2 (old version I worked on). I thought to look where there are backups DBVersion (db / maintenance.php only?).
So I think may be an automatic action during a session time too long, but I do not know what are they? (Where are they managed?)
Did you have any idea what could cause it? (security? a place where the value of the version? other things we care?)
24 May 2013 19:57 #2 by babynus
Replied by babynus on topic Re: dbVersion'problem
There is not automatic "reverse" update.
What can happen is retriving parameters from the database (they are normally cached in Session), when a user saves Global Parameter screen.
But maybe your implementation may have brought this strange behavior.
The following user(s) said Thank You: DjackJack
25 May 2013 01:34 #3 by DjackJack
Replied by DjackJack on topic Re: dbVersion'problem
I found a friend working on the same database, but with a different version. sorry for the inconvenience
