ProjeQtOr free project management software - copy Document - ProjeQtOr
copy Document
11 Jun 2013 16:01 - 11 Jun 2013 16:03 #1 by DjackJack
copy Document was created by DjackJack
hi,
I would like to know where you manage the copies of documents and documentVersions?
Last edit: 11 Jun 2013 16:03 by DjackJack.
13 Jun 2013 10:33 #2 by babynus
Replied by babynus on topic Re: copy Document
Like any other object, in :
/model/persistence/SqlElement.php->copySqlElement()
13 Jun 2013 11:14 #3 by DjackJack
Replied by DjackJack on topic Re: copy Document
Thank you but I will wish a little more information about how to insulate the case document because I think there is a problem over there.
Indeed, when you copy a version, the version id is copied too, while for a new document version should start from 0.
what is the field "IsReF" Document Object?
13 Jun 2013 11:44 #4 by babynus
So you'll probably find what you expect in the save() function of each dedicated class (/model/Document.php and /model/DocumentVersion.php) that extend the default save() function called by the copy() function (in /model/persistence/SqlElement.php)
13 Jun 2013 14:18 #5 by DjackJack
Is there a way to know if the save () function is called when a copy or during normal processing?
13 Jun 2013 14:46 #6 by babynus
It is always : it is the only way to save data to database.
