ProjeQtOr free project management software - Plantage sur planning par ressource - ProjeQtOr
24 Jul 2013 09:35 #1 by Trempels
Bonjour,
Nouveau venu sur Projector, je teste le produit afin d'en comprendre la philosophie et voir les adaptations possibles selon mes besoins. Pour l'instant , je suis satisfait des premiers résultats. Félicitation pour le travail accompli.
Alors qu'hier tout s'est passé normalement, je me reconnecte aujourd'hui et constate sans avoir fait aucune modif que tout fonctionne sauf ... le planning par ressource qui reste en attente (sablier en cours), sans aucun résultat. Si je change d'option, j'obtiens le message "requête en cours".
Je suis sur la version 3.3.2.
Un peu inquiet car évidemment si cela arrive en production ...
Merci d'avance
24 Jul 2013 11:20 #2 by climb4fun
Hi Tremples,
would it be an effort to post in English? :dry: May some more people could help you.
Klaus
24 Jul 2013 12:20 #3 by Trempels
This time in english.
As administrator, only since this morning and without any modification before, I'm not able anymore to see the planning by resource. Everything else is functionnaly ok, but the planning by resource is running without result. Connected as user, no problem, he can see his planning.
Thanks in advance.
24 Jul 2013 12:25 #4 by babynus
Could you check the log file and report any error in this file ?
Could you also check for any javascript error reported in the console ?
25 Jul 2013 09:40 #5 by Trempels
In response to you Klaus (Weisst Du, dass Du viel Glück hast, in München zu leben?) : no message, no error.
I found the solution to unlock the problem, but without understanding the cause and the real solution to recover something clean. Obviously I've done something wrong. As I said (in french) I'm new on the product and I do a lot of tests too see if I can use it for real.
Under Resource Planning, the option "Show Project level" was checked; unchecked it resolved the blockage. Now in the Task column appears a blank resource in the firt line with an activity. When I look at this activity, I can see the normal assigned resource and another resource "1" (I can't delete it, maybe because there is real work on it). This resource is not in my resource list. Is this an automatically resource when the activity is assigned without resource ? In this case, what is the explanation for my initial problem (temporaly resolved with the option ""Show Project level") ?
Thanks in advance for any idea.
25 Jul 2013 11:46 #6 by babynus
Could you please post a print screen of the Resource planning as is appears now (I don't fully understand the explanation)
