ProjeQtOr free project management software - advices on implementing reserve management solution - Page 2 - ProjeQtOr
24 Aug 2013 22:26 #7 by leodom
well, still progressing, and working on import, hoping not to spend more time on solution than creating all new. After some trials, I eventually had some little test file imported, but something is not right about wbs. (I used csv example as base, but had to insert a type column with the right id's value, something that was not obvious, after getting frustrated with 'invalid controls - type mandatory')
I imported a file (
File Attachment:
File Name: hb45ddab.xlsx
File Size:5 KB
) containing 4 lines, a sub project of a main one, a sub project for it, and 2 sub projects for the later. Imported project shows names, id, type and status as they should.
in the projects tab, they do show, with the right 'is a sub project of' listed, but wbs is not right, (instead of 2.1, 2.1.1, 2.1.1.1 and 2.1.1.2, they show as 3, 4, 5 and 6 respectively)
In planning view, the project names don't show up.
File Attachment:
File Name: h7a34d9b.pdf
File Size:1,214 KB
Any idea on what I should do to be able to import my projects with a correct wbs and project name ?
24 Aug 2013 23:34 #8 by babynus
I reproduced the behavior you describe.
It seems to be a bug on import.
Ticket #1178 recorded.
As a workaround : I just updated project 20 : reset "is sub-project of" to null and then set it back to correct value : all is fixed, even sub-projects of 20 are correctly updated automatically.
25 Aug 2013 05:52 - 25 Aug 2013 08:28 #9 by leodom
sad bug ! Thanks for your quick reply, though...
I saw the mentionned ticket #1178 in the track section, but can't add to it... Any way I could help ?
I imported a bigger test file, workaround does work, but only for reseted project line, not updating subs and such, quite a tedious work for 200+ projects...
In planning mode, if I click on a 'unnamed' project and save it, name then shows, but wbs is not corrected.
Lookind at database, it seems the actionsplanningelement table misses values for imported data (such as fields refname, topId, topRefType, topRefId), beside the wrong values in fields wbs and wbsSortable
Last edit: 25 Aug 2013 08:28 by leodom. Reason: deleted a useless question
27 Aug 2013 00:50 #10 by babynus
Thnaks for this complemtentary infirmation.
I added it as a note to the ticket.
Will be some help to find a fixing...
27 Aug 2013 05:37 #11 by leodom
would you have an idea where I should look to understand the import processs ? I have minimal knowledge about php and mysql but I may help somehow. Maybe there is just one column to fill in the import for the wbs to be calculated rightly :woohoo:
should I open a separate thread to get input from the forum ?
27 Aug 2013 23:26 #12 by babynus
The main code for import is in /model/Importable.php, in the import() method.
But the issue may also be in the /model/PlanningElement.php.
I'll have a look as soon as I get some time...
(very busy this week, sorry)
