ProjeQtOr free project management software - installation fail - ProjeQtOr
installation fail
18 Sep 2013 12:00 #1 by ixir
installation fail was created by ixir
I have error what is wrong :(
ERROR : Impossible to load class UserSession
=> Not found in ../model/UserSession.php
=> Not found in ../model/persistence/UserSession.php
i use easy php,
i coped files under root, edit parameters.php, crated database "projectorria" in php myadmin, creted
http://myip:8080/projectorria
$paramDbType='mysql';
$paramDbHost='localhost';
$paramDbUser='root';
$paramDbPassword='';
$paramDbName='projectorria';
$paramDbDisplayName='projectorria';
$paramDbPrefix='';
phpmyadmin
User Host Type Privileges
root localhost global ALL PRIVILEGES
18 Sep 2013 12:59 #2 by babynus
Replied by babynus on topic installation fail
It is clear you will not find UserSession.php as there is no such file.
In fact it seems you have some issue coming from other installed php application : you retrieved some session that tried to open UserSession class, but this one does not exist in Project'Or RIA.
Try to clear php session cache.
If it still does not work, try to install a clean easyPhp (without any other application).
For information, you should not edit parameters.php yourself : the program does it.
Try and remove /tool/paraetersLocation.php and run again to get configuration screen.
23 Sep 2013 21:33 #3 by ixir
Replied by ixir on topic installation fail
yes you are right,
i have a another php software installed and loging timeout was set never expire,
when i log out, now projectorria works good,
thank you!
