ProjeQtOr free project management software - send mail problem - ProjeQtOr
send mail problem
24 Sep 2013 23:04 - 24 Sep 2013 23:39 #1 by ixir
send mail problem was created by ixir
Hi ,
i have another open source software at my company server and can send mails with my mail adress, but with projectorria can not send,
could you check the image attached?
left one is other sofware settings works well, rigt one is projectorria settings,
where can be the problem ?
Last edit: 24 Sep 2013 23:39 by ixir. Reason: image
24 Sep 2013 23:22 #2 by babynus
Replied by babynus on topic send mail problem
Image is not attached :unsure:
24 Sep 2013 23:40 #3 by ixir
Replied by ixir on topic send mail problem
hi,
now i added
24 Sep 2013 23:59 #4 by babynus
For autentified connection, format for host is specific. It should be prefixed with protocole (ssl:// or tls:// or smtp://)
Have a look at user manual for example.
(Your other php code uses PhpMailer Library. Very Good one. Maybe will be included in Project'Or RIA in a next version)
25 Sep 2013 08:05 - 25 Sep 2013 08:05 #5 by ixir
Tried 3 protocol you wrote but still not sending mail,
it can be cause of port?
And i tried to ping smtp server with 3 protocol you wrote but can not find the server,
without protocol ping is ok.
Any idea?
Last edit: 25 Sep 2013 08:05 by ixir.
25 Sep 2013 09:51 #6 by babynus
Have you tried anonymous access (without protocole, without user / password) ?
