ProjeQtOr free project management software - Relation between project and product/versions - ProjeQtOr
22 Oct 2013 16:51 #1 by sam
- I defined a project PP
- I defined prod_01 and prod_02 as 2 products of my project PP.
- I defined also subprod_01 and subprod_02 as sub-products of prod_01.
All these are related to proejct PP.
When i create any elements within project XX, all these products and sub products are available. Is it normal?
22 Oct 2013 19:26 #2 by babynus
It is designed this way.
There is not constraint between product and project.
There is a link between product version and project, mostly to ease input.
Products could be limited to projects of the corresponding versions, but as from today, it could be a regression for some users.
23 Oct 2013 15:07 - 23 Oct 2013 15:07 #3 by sam
OK, understood, but it is a bit unconfortable as "project" behaves like a filter for the rest of the application.
Is their a possibility to ask the community which behavior would best fit its needs?
thanks.
Last edit: 23 Oct 2013 15:07 by sam.
23 Oct 2013 16:13 #4 by babynus
Yes it's possible... anyone can reply ot this post !!!
But just keep in mind that Products and Documents are the only elements which are not systematically prject dependant.
23 Oct 2013 16:14 #5 by sam
Thanks. I'll keep this in mind to organize data around.
