ProjeQtOr free project management software - [Solved] - No planning in reports for some project - ProjeQtOr
04 Nov 2013 14:18 - 21 Nov 2013 16:27 #1 by Drubs2010
Why doesn't the planning reports, as monthly planning project/activity/resource, show any planned work? However, there are planned work in the Gantt.
regards,
Drubs2010.
Bonjour,
Pourquoi les états de planning, tel que Planning Projet/activités/Ressources, ne montrent pas le travail planifié? Pourtant, il y a du travail planifié sur l'état du Gantt.
Cordialement,
Drubs2010.
Last edit: 21 Nov 2013 16:27 by Drubs2010.
04 Nov 2013 15:26 #2 by climb4fun
Hi Drubs,
in my report it shows planned work. Did you run planning? Planning figures are italic and colored different.
Klaus
04 Nov 2013 16:39 - 04 Nov 2013 17:01 #3 by Drubs2010
Thanks, that's it.
It's because I checked fix planning in the project. I unchecked it, but it wasn't enought, I had to run planning even if I did it before the check. Is that clear?
Conclusion : When we uncheck fix planning, we must run planning.
Drubs2010.
Last edit: 04 Nov 2013 17:01 by Drubs2010.
05 Nov 2013 17:12 #4 by climb4fun
Hi Drubs2010,
I'm really please I could help you. Just let me add to be excact:
  • If planning is fix, then no replanning will be done.
  • If you didn't run planning before fix the planning, then there will be no planning values - hence they are not displayed as plan value.
I hope this enlightens things.
Klaus
