ProjeQtOr free project management software - Problem for install ProjeQtor 4.2.3 with Postgresql 8.4 - Page 3 - ProjeQtOr
10 Jul 2014 12:38 #13 by Mams
My install is always KO.Any error message. Which parameters do I use for configure Postgresql (user and right, database name, ...)?
Thank you so much for your reply.
10 Jul 2014 13:29 - 10 Jul 2014 13:31 #14 by babynus
Parameters must be defined in config :
host : server when your database is
port : port to pgsql database (5432 by default for pgsql)
database : an existing database created on pgsql (with utf8 enciding)
user / password : a valid pgsql role granted to create tables on database.
Also check that :
user can access the database and select all tables adn create any type of object (table, sequence)
user must be able to connect to pgsql from PHP server : the rights defined in pg_hba.conf may be very restrictive.
Last edit: 10 Jul 2014 13:31 by babynus.
