ProjeQtOr free project management software - ..com/manual/manual.php?section=Today issues "404 not found" - Page 2 - ProjeQtOr
<sub-domain>.<domain>.com/manual/manual.php?section=Today issues "404 not found"
24 Sep 2014 18:48 #7 by gerold.kriechbaumer@gmx.net
Accessing sub-domain.domain.com/manual/manual.php directly, results to this apache log file entry, which I guess is similar:
"GET /manual/manual.php HTTP/1.1" 404 409 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/37.0.2062.120 Safari/537.36"
Still further ideas or suggestions?
24 Sep 2014 20:31 #8 by babynus
It really seems to be an apache configuration.
Maybe you have some directory directive with deny clauses or something like that (I'm not an apache expert)
It may be in httpd.conf or other included files or in .htacces file (do you have any .htaccess file ?)
What you can try, as a test :
1) set access right to 777 to this /files/manual directory and contained files, and then try and access directly to sub-domain.domain.com/manual/manual.php
2) then retrieve /manual directory from install package, copy it for instance under /files, set access right to 777 to this /files/manual directory and contained files, and then try and access directly to sub-domain.domain.com/files/manual/manual.php
If 1) works, then it is the solution.
If 2) works but not 1) then it is sure it is an apache configuration issue.
25 Sep 2014 00:23 #9 by gerold.kriechbaumer@gmx.net
I'm sorry, but I do know nothing about "directory directive with deny clauses".
It may be in httpd.conf or other included files or in .htacces file ...
I guess that httpd.conf is accessible only by using my web hosters' web application menu (called Httpd Spezial) and it looks and is set for the sub-domain like the following:
... (do you have any .htaccess file ?)
In all the directories which are accessible for me, I could not find any .htaccess file.
1) set access right to 777 ...
The access rights are currently 755 for all directories and 644 for all files. I have not changed any access rights, but renamed the directory /manual to /man and called manual.php directly by using sub-somain.domain/man/manual.php and - voila - this works! So the directory where manual.php resides can be named anything you like but NOT "/manual"!?
Do you have any idea what is going wrong here?
25 Sep 2014 00:30 #10 by babynus
Maybe you should ask your web hoster about this limitation.
(why /manual cannot be reached ...)
