ProjeQtOr free project management software - installation issue - ProjeQtOr
installation issue
18 Aug 2011 06:07 #1 by Nareshkosgi
I am trying to install project on my server. I have apache2, mysql and php installed. I am able to get to the configuration screen but when I hit ok I do not get moved to the next screen. I do see the wheel though but after that I just stay on the same screen. I tried to debug it using firebug as was suggested in another thread. The firbug gave me this error:
Unable to load /tool/configCheck.php?
I thought it might have been a permissions issue but I am able to server other pages without a problem (the main.php came up without a problem so I am not sure if permissions is the issue)
Any help will be appreciated and thank you ahead of time.
18 Aug 2011 10:19 #2 by babynus
Replied by babynus on topic RE : installation issue
On configuation screen, do you always see the week or does it dissepear ?
If so, you must have a message and a new button on bottom of sreen (maybe you have to scroll down).
If spinner never stops :
Check write access to the "log" directory.
Try and set debuglevel to 0 (no log).
Check if you get any apache error.
Also check database access.
Regards.
21 Aug 2011 22:19 #3 by ThierrC49
Replied by ThierrC49 on topic RE : installation issue
Hello, I had the same problem and now has solved by putting php.ini /windows/system32
see post projectorria.toolware.fr/forum/viewtopic.php?id=153
I hope you have the same bad config like me and this way help you
BR
Thierry,
30 Dec 2011 03:47 #4 by parmato
Replied by parmato on topic RE : installation issue
babynus wrote: Hi,
Regards.
Hi babynus,
I am a newbie, i experiencing the same problem and i have scroll down but there is no new button. Can you show me how to set debuglevel to 0 and how to make sure that database access is right?
Thank's for your kindness.:)
30 Dec 2011 12:24 #5 by babynus
DebugLevel can be set in the parameters in the configuration screen.
When pressing "OK", first thing done is database access.
If access is wrong, an explcit messageis displayed.
