ProjeQtOr free project management software - Real Work allocations.... - Page 2 - ProjeQtOr
27 Apr 2015 18:42 #7 by babynus
Replied by babynus on topic Real Work allocations....
is it on etc/php5/apache2/php.ini ???
Yes.
And don't forget to restat php (or apache) to take change into account B)
27 Apr 2015 18:53 #8 by Durou C
Replied by Durou C on topic Real Work allocations....
I have change the value of max input to 4000,
but it is not work :(
27 Apr 2015 19:03 #9 by Durou C
i did, i, terminal:
sudo /etc/init.d/apache2 stop
and
sudo /etc/init.d/apache2 start
and it do not work, what's problem :( :(
27 Apr 2015 19:05 #10 by Durou C
this is what I have on the log file:
2015-04-27 19:01:54 ***** ERROR ***** GD Library not enabled - impossible to draw charts
2015-04-27 19:01:54 ***** ERROR ***** GD Library or FreeType Librairy incorrect or not correctly installed - impossible to draw charts
2015-04-27 19:02:13 ===== TRACE ===== WARNING - Left work not retrieved from screen
2015-04-27 19:02:13 ===== TRACE ===== - Maybe max_input_vars is too small in php.ini
2015-04-27 19:02:13 ===== TRACE ===== - Assignment #39 on Activity #25 for resource #6 - PREVOSTO Jonathan
2015-04-27 19:02:13 ***** ERROR ***** ERROR *****
2015-04-27 19:02:13 ***** ERROR ***** on file '/var/www/projeqtor/tool/saveImputation.php' at line (84)
2015-04-27 19:02:13 ***** ERROR ***** cause = Error - Maybe max_input_vars is too small in php.ini
27 Apr 2015 19:17 #11 by babynus
Your parameter is not taken into account.
Maybe it is not the good php.ini.
Also notice that GD library is not installed : you'll not be able to display charts in reports.
27 Apr 2015 19:20 #12 by Durou C
so I have an other PHP.ini ?
