ProjeQtOr free project management software - import from web2project - ProjeQtOr
10 Jul 2015 23:58 #1 by ok
import from web2project was created by ok
Hi ,
I'm working on an old platform based on web2project , I have built a new one using ProjeQtor and I want to import data from the old one to the new .
is there any way to perform such kind of tasks automatically or I'm obligated to copy and past all the data manually ? :(
Thank you
11 Jul 2015 12:19 #2 by babynus
Replied by babynus on topic import from web2project
if web2project can export data, you should be able to import data into ProjeQtOr using import feature.
But you'll possibly need to have some formatting, as there is no automatic formatting from web2project to ProjeQtOr.
The following user(s) said Thank You: ok
