ProjeQtOr free project management software - Validated Work - ProjeQtOr
Validated Work
20 Jul 2015 13:32 #1 by Durou C
Validated Work was created by Durou C
How is possible to change the value of Validated work/ cost ?
20 Jul 2015 18:20 #2 by babynus
Replied by babynus on topic Validated Work
Validated work and cost can be directly entered on activities and project.
The input may be locked depending on consolidation mode choosen on global parameters screen, so that values may only be entered on elementary tasks.
21 Jul 2015 07:24 #3 by Durou C
Replied by Durou C on topic Validated Work
is it possible to unlock validated work and cost after entering a value ?
21 Jul 2015 16:25 #4 by babynus
On "Parameters" => "Global Parameters", section "Planning", for item "consolidate validated work & cost" select never.
Save.
Then, you'll alway be able to enter validated work and cost, but values will never be consolidated from tasks up to projects.
21 Jul 2015 16:53 #5 by Durou C
tks it works
