ProjeQtOr free project management software - Progress of a project - ProjeQtOr
05 Aug 2015 23:26 #1 by Terfas Elmehdi
Is there a way to change the progress percentage of a project or an activity mannualy?
06 Aug 2015 09:36 #2 by babynus
Replied by babynus on topic Progress of a project
Not the calculated progress, as it is ... calculated.
Only way to change progress is to add real work : progress = real / (real + left)
But you have another progress : overall progress, which is a value selected from a list.
You can also manage the list to define all possible values.
The following user(s) said Thank You: Terfas Elmehdi
