ProjeQtOr free project management software - [SOLVED] Copy requirement as new project? - ProjeQtOr
26 Aug 2015 15:21 - 16 Sep 2015 11:28 #1 by papjul
All our projects come from business requirements. Sometimes requirements are cancelled but when they become a real project, it would be good to be able to copy requirement as new project because it's dull and repetitive to copy name, description, estimated work, etc…
So why can't we copy requirement (or any other element) as a new project?
Thank you,
Last edit: 16 Sep 2015 11:28 by papjul.
27 Aug 2015 18:34 #2 by babynus
Because requirement should be an item of a project, and not a complete plroject.
It seems strange to me to transform a single requirement into a project.
IMO a project should contain several (upo to many) requirements.
28 Aug 2015 11:08 - 28 Aug 2015 11:09 #3 by papjul
Sorry, I clicked on Solved by mistake.
Here is how we work:
We have big projects:
1. MY PROJECT
We have sub projects:
1.1 REQUEST FOR CHANGE 1
1.2 REQUEST FOR CHANGE 2
- Each request (change or fix) come from our customers and is about ONE requirement. Example: change the color of the button.
- For this single request, we will have everything, from prestudy, to business requirements, to specs, to developments, to tests, to UAT and to deployment, etc.
- When the requirement is in prestudy, we study the feasibility and if or not it will become a real project, if we will cancel it or do it later when we have the budget. At this state, the requirement is a requirement, not a project (yet).
- When we validate the requirement, it becomes a single project (from specs to deployment).
- We have two workflows in parallel: a financial workflow (statuses quotation, contract, order, etc, to know at which state we are) for the requirement, and a project workflow (statuses prestudy, specs, etc) for the project.
So requirements and projects are linked as 1:1 in UML. I checked with projects manager, it will always be like that (except when initiating a new big project, which should be rare).
Thank you,
Last edit: 28 Aug 2015 11:09 by papjul.
29 Aug 2015 15:33 #4 by babynus
You really defined a project for a request to change the color of a button ?
And what is the requirement linked to ? (if not to a project)
How do you manage work spent on requirement feasibility study ? (if not inside a projet)
Really I thing you should manage your sub-projects as activitiies.
1) you can copy a requirement into an activity
2) an activity can be split into sub activities
3) Requirements and acitivites can belong to same main project
4) if you please, you can define some activity type called "project"
It really makes sense to me to define an activity (and not a project) to change the color of a button, and not a project.
Do the project managers manage 1 and 1 only requirement ?
16 Sep 2015 11:26 #5 by papjul
Yes, our suppliers invoice every little changes we ask them so it's a whole project. And I can't change the way they/we work as I have no influence on it.
Among other reasons, a Change Order is linked to every financial elements such as the Quotation, Order, Invoice, etc and we can't link and filter activities as easily and as intuitive as with projects.
Isn't adding Project to Copyable table a better way to solve this issue?
16 Sep 2015 11:48 #6 by babynus
It is not so easy as Project is the main entry point and key to manage access rights.
If may lead to more issues than solutions.
Your way to manage requirements and transform them into projects is very specific, so you should consider it as a specific evolution.
You can request for a quote to implement it throught the Contact form if you wish.
