ProjeQtOr free project management software - [SOLVED] Problem ldap search - Page 3 - ProjeQtOr
03 Sep 2015 12:50 - 03 Sep 2015 12:52 #13 by babynus
Replied by babynus on topic Problem ldap search
All depends on your LDAP configuration.
Default values are :
LDAP base dn :
dc=my-domain,dc=com
LDAP user filter :
uid=%USERNAME%
These values work fine for basic OpenLDAP (with my-domain replaced by correct domain)
With this configuration you should have something like that :
LDAP user :
cn=Manager,dc=my-domain,dc=com
Last edit: 03 Sep 2015 12:52 by babynus.
03 Sep 2015 16:04 #14 by Coyote
Replied by Coyote on topic Problem ldap search
that it is possible to send you the config with private message ?
03 Sep 2015 18:08 #15 by babynus
Yes
send at This email address is being protected from spambots. You need JavaScript enabled to view it.
04 Sep 2015 10:54 #16 by Coyote
i have send a email, thanks
04 Sep 2015 14:27 #17 by babynus
Problem found, analysed ... and solved.
Quick fix (as a workaround) is to change line 2665 in /model/persistence/SqlElement.php from
if (getSessionUser()->id) {
to
if (1) {
More accurate fix will be included in V5.1
The following user(s) said Thank You: samuelcochard
07 Sep 2015 07:20 #18 by samuelcochard
Replied by samuelcochard on topic Problem ldap search
It works ! Thx
