ProjeQtOr free project management software - [SOLVED] Delete Wrong test project - ProjeQtOr
01 Sep 2015 22:41 #1 by Petipotame
Hello, i'm new user of projeqtor and i did many tests and trials for training, so i create projects, create ressources, affectations, activities etc... and now i want to delete my id#1 project to clean everything and i can't do it.
Software is displaying : Contrôles invalides / Impossible de supprimer un élément avec du travail réel
i've got admin rights, checked all habilitations etc...
somebody can help?
02 Sep 2015 00:00 #2 by babynus
Replied by babynus on topic Delete Wrong test project
You entered some real work in "Real Work Allocation" screen (imputations).
So you cannot delete items with real work : it real work is entered, it means there is some work done, that should not be deleted.
02 Sep 2015 07:26 #3 by Petipotame
Hello and thank you Babynus.
i read it in the documentation, i put this question in the forum to be sure that Admin can or can't have the rights to do such delete operations in case of mistake. so i will move the project to close and he will not appear in the list;
