ProjeQtOr free project management software - [SOLVED] Teams are not working at fully time on project 3 - Page 2 - ProjeQtOr
27 Oct 2015 18:06 #7 by El Wallos
so, if I have my configuration in my test case is:
33% Project 1 ---> "regular between dates" ---> cyclic tasks
33% Projet 2 ---> "reguler between dates" ---> cyclic tasks
33% Projet in general ---> ASAP
What is your recommendation/configuration using "regular plan" for my test case?
Because if I keep 100% in my activity assigment with "regular", I think my Real Work Allocation should not be right with my expectation (33% suggests every day for my two cyclics tasks)
27 Oct 2015 18:10 #8 by babynus
Just try.
28 Oct 2015 09:26 #9 by El Wallos
Thanks a lot Babynus, you are right. :woohoo:
It is easier than with change the different rates!!!
But I'm not sure why it is correct? it is because the assigned work was multiple by the rate to calculate the assigned work?
28 Oct 2015 09:28 #10 by El Wallos
And it isn't depend to the number of assigned ressources... it is better. :evil:
28 Oct 2015 12:23 #11 by babynus
Yes
