ProjeQtOr free project management software - [SOLVED] Problem Menu - ProjeQtOr
04 Nov 2015 13:48 #1 by El Wallos
Problem Menu was created by El Wallos
Hi
I installed a new server with ProjeQtOr on Linux (LAMP) and I have a problem with the display (tested with IE 8, Chrome version 43.0.2357.81).
I have no menu item as create or modify, what is wrong in my configuration? :blush:
04 Nov 2015 13:51 #2 by El Wallos
Replied by El Wallos on topic Problem Menu
Let me know if you need more logs or details?
04 Nov 2015 14:03 #3 by El Wallos
I attach the log:
[Wed Nov 04 14:02:27 2015] [error] [client XXX PHP Fatal error: Class 'DOMDocument' not found in /var/www/html/projeqtor/model/ColumnSelector.php on line 111, referer: http://XXXX:XXX/projeqtor/view/main.php
04 Nov 2015 14:34 #4 by El Wallos
Just to help, the issue was resolved. The Php-xml was not installed correctly. After reinstall it, everything looks fine.
05 Nov 2015 11:16 #5 by babynus
Replied by babynus on topic Problem Menu
Check access rights.
Maybe you connected with profile with no write access.
To be sure, also check log file for errors and browser console for errors.
Cleaning of browser cache may also help.
05 Nov 2015 11:22 #6 by El Wallos
Thanks Babynus, the problem was on my config, Php-xml was not installed correctly.
Right now, I have no problem.
