ProjeQtOr free project management software - Attachment section does not appear after upload - Page 5 - ProjeQtOr
08 Dec 2015 08:56 #25 by babynus
OK,
So, if it is an image, I guess you have somme issue with thumb generation.
Most likely, php user don't have write access to /projeqtor/files/thumbs folder (or no right to create that folder if non existing).
Or possibly some graphic library is missing.
In all cases, you must have some error loggued in projeqtor log file.
08 Dec 2015 09:04 #26 by babynus
I looked again in log files you posted.
I finaly found on oldest one (I must admit I first looked only at the 3 most recent ones) :
2015-11-16 11:17:00.908 ***** ERROR ***** ERROR *****
2015-11-16 11:17:00.908 ***** ERROR ***** on file '/var/www/html/projeqtor/tool/saveAttachment.php' at line (244)
2015-11-16 11:17:00.908 ***** ERROR ***** cause = mkdir(): Permission denied
It is clear : php user don't have write rights on /projeqtor/files folder to create the expected thumbs folder.
So either give write rights to php user on /projeqtor/files
or create /projeqtor/files/thumbs and give write rights to it for php user.
08 Dec 2015 15:28 - 09 Dec 2015 21:32 #27 by mendo15
Please see the following screenshots for permission for files.
I believe the permissions are okay?
Last edit: 09 Dec 2015 21:32 by mendo15.
08 Dec 2015 20:16 #28 by mendo15
Is it normal that the thumbs folder is completely empty?
09 Dec 2015 17:49 #29 by babynus
Yes, they seem correct.
09 Dec 2015 17:52 #30 by babynus
Not it is not, it should at least contains thumbs for attachements as a picture.
And the issue sure comes from this point.
New must understand why generation of thumb fails...
Are you sure you have nothing in ProjeQtOr log files ?
And maybe in Apache error log file ?
Could you also chack prerequisites as defined : www.projeqtor.org/en/product-en/technica...uct-prerequisites-en
