ProjeQtOr free project management software - [SOLVED] Upgraded to 14.1vc9 but not connecting - ProjeQtOr
23 Nov 2015 19:47 #1 by kay
Hi, I need help!
My 13.1vc9 Version is working and I updated to 14.1vc9....I was able to successfully go to the Parameters page and set
my options accordingly, clidk OK ....seeing the "saved files notice" ....clicked on the "Connect Button" .....it was thinking and
then it failed. This is the error I received "ERROR : An error occurred on 2015-11-23 at 18:47:55".
I cleared my browser and rebooted a new browers, did the same technique as posted earlier...same thing happens.
Can you please help with what looks like a minor problem, but not a fully understood problem for me? I also checked phpadmin, im not seeing
my databases files in there also
Here's another Question, How come this continues to happen every time we upgrade(migration/Intergration) would be very helpful or some type of
easy fix)
****by the way I did a stare and compare to make sure that I was adding the same options
23 Nov 2015 20:43 #2 by babynus
Please check log file and post it here.
"ERROR : An error occurred on 2015-11-23 at 18:47:55" indicates ytou have complete error logged on log file.
25 Nov 2015 08:51 #3 by kay
Easy PHP Error Log*****
25/11 02:35:26 EasyPHP EasyPHP Servers starting
25/11 02:35:30 EasyPHP Apache CreateProcess "C:\PROGRA~2\EASYPH~1.1VC\binaries\apache\bin\eds-httpd.exe"
25/11 02:35:30 EasyPHP CreateProcess "C:\PROGRA~2\EASYPH~1.1VC\binaries\mysql\bin\eds-mysqld.exe --defaults-file="C:\PROGRA~2\EASYPH~1.1VC\binaries\mysql\my.ini" --language=english"
25/11 02:35:35 EasyPHP EasyPHP Check version
Mysql Error Log *****
2015-11-25 02:35:32 5624 [Note] Plugin 'FEDERATED' is disabled.
2015-11-25 02:35:32 5624 [Note] InnoDB: The InnoDB memory heap is disabled
2015-11-25 02:35:32 5624 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2015-11-25 02:35:32 5624 [Note] InnoDB: Compressed tables use zlib 1.2.3
2015-11-25 02:35:32 5624 [Note] InnoDB: Not using CPU crc32 instructions
2015-11-25 02:35:32 5624 [Note] InnoDB: Initializing buffer pool, size = 20.0M
2015-11-25 02:35:32 5624 [Note] InnoDB: Completed initialization of buffer pool
2015-11-25 02:35:32 5624 [Note] InnoDB: Highest supported file format is Barracuda.
2015-11-25 02:35:32 5624 [Note] InnoDB: The log sequence numbers 1626154 and 1626154 in ibdata files do not match the log sequence number 1626164 in the ib_logfiles!
2015-11-25 02:35:32 5624 [Note] InnoDB: Database was not shutdown normally!
2015-11-25 02:35:32 5624 [Note] InnoDB: Starting crash recovery.
2015-11-25 02:35:32 5624 [Note] InnoDB: Reading tablespace information from the .ibd files...
2015-11-25 02:35:32 5624 [Note] InnoDB: Restoring possible half-written data pages
2015-11-25 02:35:32 5624 [Note] InnoDB: from the doublewrite buffer...
2015-11-25 02:35:36 5624 [Note] InnoDB: 128 rollback segment(s) are active.
2015-11-25 02:35:36 5624 [Note] InnoDB: Waiting for purge to start
2015-11-25 02:35:36 5624 [Note] InnoDB: 5.6.15 started; log sequence number 1626164
2015-11-25 02:35:36 5624 [Note] Recovering after a crash using mysql-bin
2015-11-25 02:35:36 5624 [Note] Starting crash recovery...
2015-11-25 02:35:36 5624 [Note] Crash recovery finished.
2015-11-25 02:35:36 5624 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
2015-11-25 02:35:36 5624 [Note] - '127.0.0.1' resolves to '127.0.0.1';
2015-11-25 02:35:36 5624 [Note] Server socket created on IP: '127.0.0.1'.
Apache Access Log****
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET / HTTP/1.1" 200 3053
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /images_easyphp/top_title.png HTTP/1.1" 200 1119
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /images_easyphp/top_section_in.gif HTTP/1.1" 200 55
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /images_easyphp/top_background.gif HTTP/1.1" 200 60
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /images_easyphp/top_section_out.gif HTTP/1.1" 200 56
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /icons/blank.gif HTTP/1.1" 200 148
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /icons/folder.gif HTTP/1.1" 200 739
127.0.0.1 - - [25/Nov/2015:02:40:01 -0500] "GET /images_easyphp/admin.gif HTTP/1.1" 200 64
127.0.0.1 - - [25/Nov/2015:02:40:02 -0500] "GET /favicon.ico HTTP/1.1" 404 1150
127.0.0.1 - - [25/Nov/2015:02:40:09 -0500] "GET /projeqtor/ HTTP/1.1" 200 1899
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/css/projeqtor.css HTTP/1.1" 200 87883
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/css/common.css HTTP/1.1" 200 60627
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/css/projeqtorIcons.css HTTP/1.1" 200 55510
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/css/FileInput.css HTTP/1.1" 200 2327
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/external/dijit/icons/commonIcons.css HTTP/1.1" 200 4734
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/external/dijit/themes/dijit.css HTTP/1.1" 200 35194
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/external/dojo/resources/dojo.css HTTP/1.1" 200 1735
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/img/titleSmall.png HTTP/1.1" 200 18670
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/css/images/spinner10.gif HTTP/1.1" 200 3289
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "GET /projeqtor/view/img/logo.ico HTTP/1.1" 200 2494
127.0.0.1 - - [25/Nov/2015:02:40:10 -0500] "POST /projeqtor/view/main.php HTTP/1.1" 200 252
Apache Error Log****
[Wed Nov 25 02:35:31.826883 2015] [core:warn] [pid 8204:tid 144] AH00098: pid file C:/Program Files (x86)/EasyPHP-DevServer-14.1VC9/binaries/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Wed Nov 25 02:35:35.838911 2015] [mpm_winnt:notice] [pid 8204:tid 144] AH00455: Apache/2.4.7 (Win32) PHP/5.4.24 configured -- resuming normal operations
[Wed Nov 25 02:35:35.917029 2015] [mpm_winnt:notice] [pid 8204:tid 144] AH00456: Apache Lounge VC9 Server built: Nov 28 2013 10:45:22
[Wed Nov 25 02:35:35.917029 2015] [core:notice] [pid 8204:tid 144] AH00094: Command line: 'C:\\PROGRA~2\\EASYPH~1.1VC\\binaries\\apache\\bin\\eds-httpd.exe -d C:/Program Files (x86)/EasyPHP-DevServer-14.1VC9/binaries/apache'
[Wed Nov 25 02:35:35.979528 2015] [mpm_winnt:notice] [pid 8204:tid 144] AH00418: Parent: Created child process 8196
[Wed Nov 25 02:35:37.229596 2015] [mpm_winnt:notice] [pid 8196:tid 4] AH00354: Child: Starting 64 worker threads.
25 Nov 2015 09:02 #4 by babynus
Thanks for the logs, but I was requesting ProjeQtOr log.
Default location is in projeqtor/files/logs (one file per day), but you may have changed this in configuration step.
If you don't find log file, maybe it is the source of the issue : check that php user has write rights to the log directory.
27 Nov 2015 22:11 #5 by kay
ERROR *****
2015-11-25 08:40:11 ***** ERROR ***** on file 'C:\Program Files (x86)\EasyPHP-DevServer-14.1VC9\data\localweb\projeqtor\tool\projeqtor.php' at line (82)
2015-11-25 08:40:11 ***** ERROR ***** cause = date_default_timezone_set(): Timezone ID 'America/New York' is invalid
This is what I found in the Projeqtor/Files/logs...(FYI, I changed the Timezone back to Default Info)
Now getting This Error when I connect to LocalWeb-->
Parse error: syntax error, unexpected '?' in C:\Program Files (x86)\EasyPHP-DevServer-14.1VC9\data\localweb\projeqtor\files\config\parameters.php on line 43
28 Nov 2015 12:31 - 01 Dec 2015 17:06 #6 by babynus
1) Time zone for New York is "America/New_York" with an underscore instead of space
2) You now have issue in parameters.php, line 43 : possibly when you changed value you entered a syntax error.
Last edit: 01 Dec 2015 17:06 by babynus.
The following user(s) said Thank You: kay
