ProjeQtOr free project management software - [SOLVED] Native SQL - ProjeQtOr
[SOLVED] Native SQL
07 Dec 2015 13:59 #1 by LU611
Native SQL was created by LU611
Hy,
Is it possible to perform SQL queries on additional tables?
I created a new table to store specific calculations, but how to access it easily from a report?
thanks in advance
07 Dec 2015 14:23 #2 by babynus
Replied by babynus on topic Native SQL
Sql query is possible through SQL object.
But you'd better create an object for you new table and use framework.
The following user(s) said Thank You: LU611
