ProjeQtOr free project management software - [SOLVED] Changing variable $paramMaxAttachmentSize - ProjeQtOr
14 Dec 2015 09:43 #1 by lfd
I want to attach several files MO (+ 20MB)
But at the end of the upload I get the following message:
"The file size exceeds the limit of 2097152 bytes ($paramAttachmentMaxSize)"
How can I change this setting?
Thanks for your help
14 Dec 2015 20:35 #2 by babynus
You must change the value in the Global Parameters screen.
But this is not enough, you also have to change configuration in php.ini to increase upload_max_filesize and post_max_size
The following user(s) said Thank You: lfd, Hedia
15 Dec 2015 09:39 #3 by lfd
it works perfectly
The following user(s) said Thank You: Hedia
30 Sep 2016 17:50 #4 by Hedia
Although I did all the settings from parameter ($ param Max Attachment Size)
and the two settings in php.ini (upload_max_filesize and post_max_size) so that the attached file size matches the size set by these parameters but still I have a file size of the problem exceeds this limit
05 Oct 2016 09:57 - 05 Oct 2016 09:59 #5 by babynus
You must also increase parameter in Global Parameter screen.
Last edit: 05 Oct 2016 09:59 by babynus.
05 Oct 2016 10:24 #6 by Hedia
yes I changed the "param Max Attachment Size" Global Parameter screen and (upload_max_filesize and post_max_size) in php.in 15 GO
But still I can not attach files whose size + 6MB
How to solve this problem
