ProjeQtOr free project management software - Delete project in cascade - ProjeQtOr
15 Jan 2016 15:53 #1 by igio80
Is it possible quickly delete a project in cascade with all activity, real work and other?
15 Jan 2016 15:58 #2 by babynus
Replied by babynus on topic Delete project in cascade
Yes and no.
Yes it is possible to delete in cascade : some cascading will be available for project managers, others will require extra habilitation (specific access / can force delete )
No it is not possible to delete project with real work : it is a constraitn that will never be avoided. You will never be able to delete any item with real work. If it is finished or cancelled, just set it as "closed" (idle)
The following user(s) said Thank You: igio80
