ProjeQtOr free project management software - [SOLVED] Add field in project - planningelement - ProjeQtOr
22 Jan 2016 09:18 - 22 Jan 2016 16:00 #1 by FabienGi
Good morning,
I must add a field on the main screen "project' with a simple rule.
This field should be link to "priority'
1 - alter table : planningelement with a varchar mynewfield
2- modify lang.js (column & idcolumn)
3 - modify planningelement.php
3a - declare mynewfield
3b- add a specific rule (need to be done) case... priority -->change value of mynewfield
I can validate my project
But I loose a part of the functionality of filters & all select column.
So I need advices :)
Edit I still need advices but finally everything is fine now.
Fabien
Last edit: 22 Jan 2016 16:00 by FabienGi.
22 Jan 2016 19:34 #2 by babynus
Sorry, I don't understand where the question is...
25 Jan 2016 08:48 #3 by FabienGi
Good morning
I do not know if this is the right method.
And now I realise a screen for adding project elements and I look for a method.
I 'm not a programmer but a portfolio project manager so I'm not sure if I do it the correct way.
25 Jan 2016 10:02 #4 by babynus
Sorry, but htere is no clear question in your post, so I'm aftraid you'll get no answer...
25 Jan 2016 10:11 #5 by FabienGi
Do you have descriptions of methods ?
To add a field in existing page
To add a page in ProjeQtor
25 Jan 2016 20:45 #6 by babynus
www.projeqtor.org/en/forum/5-ask-questio...-un-objectclass#4371
Create field in /model/ObjectClass.php (for instance Project.php for project)
Create field with same name in database table.
That's all.
