ProjeQtOr free project management software - Projects are canceled without any reason - ProjeQtOr
01 Feb 2016 10:28 #1 by El Wallos
Hi
Anybody knows why a project is updated automatically to "canceled" status?
I checked the history and the historic displayed one line with my username as if I canceled this project (but I didn't canceled it, or at least, not with an update of the status).
A recalculation of all plannings could be generated this cancelation?
01 Feb 2016 13:44 #2 by babynus
Check the "cancelled" checkbox of the project, what can be done by selecting cancelled status.
Absolutely not !
01 Feb 2016 14:02 - 01 Feb 2016 14:02 #3 by El Wallos
Where can I check this? On the workflow? Could you send me more details?
I attach the history of the project.
Last edit: 01 Feb 2016 14:02 by El Wallos.
01 Feb 2016 18:19 #4 by babynus
On 01/02/2016 at 10:16:29, PM_MLT changed status from Assigned to Cancelled.
01 Feb 2016 19:50 #5 by El Wallos
Hi Babynus
As I explained you before (at least I tried to) I didn't change the status manually, that 's why I ask you : how the status is changed automatically? What i need to check? Workflow, history. ..etc
Pd: it is not the first time that it is happened.
01 Feb 2016 19:52 - 01 Feb 2016 19:53 #6 by El Wallos
My username on projector is pm_mlt, that's why I am sure that I didn't change manually the status ;-)
Last edit: 01 Feb 2016 19:53 by El Wallos.
