ProjeQtOr free project management software - [SOLVED] Document Management : way to restrain the view of directory for the choose project - ProjeQtOr
18 Feb 2016 15:14 #1 by dnaton
Hello Babynus,
I try to use the management of documents :
I created some directories per project, with subdirectories. (menu "Environemental parameters\document directories")
Now, i go to the form "Document" to create a new one.
I put name, type, select the project attached to my document and want to select the right directory.
An I see all the directories created for all projects and not only for the selected project :(
I thought I would see only the directories attached to the project in the menu "Environemental parameters\document directories"
What have I done wrong ? Is there a way to see only the directory of the selected project ?
Damien
20 Feb 2016 15:45 #2 by babynus
The project selected fpr directories works the other way round.
You go to the directory structure (open the accordion view on Document Part instead of Menu part), select directory, then insert document.
Document will be set by sefaut on the selected directory (it's working as if you insert new file on a file browser view) and if defaut project is set for directory, it is set by defaut on document.
22 Feb 2016 15:45 #3 by dnaton
I understand. But if you have many directories, you must look all the list to find the right one.
If it were possible to "apply" the filter with the selected project, the list would be shorter. What do you think about ?
Maybe an evolution for a future release..if you think it will be good.
Damien
22 Feb 2016 15:56 #4 by babynus
Request recorded.
But it's not as simle as it seems and it's important to analyse impact first : will restrict list in a way that oes not exist.
Today it is possible to store a document in a folder not dedicated to the project. With this option, it would not.
22 Feb 2016 16:00 #5 by dnaton
That's right.
You're are the best judge :)
Damien
