ProjeQtOr free project management software - Document Management - access to obsolete versions - ProjeQtOr
09 Mar 2016 17:01 #1 by psc
do you think it is possible to block download (or preview) of obsolete versions of documents?
For example, when a document is locked give access for downloading (or preview) only to the version that is marked as reference version, (or only to latest version)?
Old versions could still be accessible when unlocking the document...
Do you think this is an interesting feature?
Best regards,
Pamela
10 Mar 2016 13:54 #2 by babynus
I really don't see the interest in the document.
Moreover, what is interesting in ProjeQtOr is to link document to an item (ticket, activity, ...) and if you link the document, when you download it (from item) you'll get the latest version...
10 Mar 2016 21:35 #3 by psc
So you don't think that ProjeQtOr should be used for versioning of more general procedures
such as purchase process description / developpement procees description...?
11 Mar 2016 16:16 - 11 Mar 2016 16:16 #4 by babynus
Yes, it is possible.
But in that case, you won't acces documents directly but through a linked item. And then you'll get what you expect (I think)
Last edit: 11 Mar 2016 16:16 by babynus.
11 Mar 2016 16:35 #5 by psc
Thank you,
just tried, as linked element (to a project), I get the latest version as you say.
I might then work with administrative projects per department.
Best regards,
Pamela
11 Mar 2016 18:39 #6 by psc
Just a little add:
when accessing documents through items as linked elements we lose quick search by document names...
:side:
