ProjeQtOr free project management software - [SOLVED] restricted project view - ProjeQtOr
02 Apr 2016 15:03 #1 by cmarechal
hi,
I would like to limit the project view to the projects the manager has in responsability. However, the project view shows all the projects. Is it normal or is there a parameter to set ?
Best regards,
Christophe
02 Apr 2016 15:42 #2 by babynus
Replied by babynus on topic restricted project view
All is managed through profiles.
Project Leader defautl profile only has access to projects he is affected to...
Admin has acces to every project.
02 Apr 2016 23:39 #3 by cmarechal
Replied by cmarechal on topic restricted project view
it is the same problem with template project :
i have changed the project type and there is à filtering of the project depending of the profile.
problem solved
