ProjeQtOr free project management software - Help on document directories structure - Page 3 - ProjeQtOr
08 Apr 2016 23:01 #13 by babynus
Clear your filters : you are using some filteres referencing some column that has been renamed.
09 Apr 2016 00:13 #14 by Eugenio
I don't know which filter I should clear, because I don't have never used particular filters in ProjeQtOr.
Could not you give me some other clue? Eg, how do you rename a column?
However, do you think that I should try this in vers. 5.2.4, ie before of the upgrade of DB, or after, already in vers. 5.3.1?
10 Apr 2016 04:37 #15 by babynus
After analysis, it's not really a filter, it is the columns selection.
Use the column selection button in the list buttons, and click reset button.
All should get back to normal.
10 Apr 2016 11:49 #16 by Eugenio
Thanks ... that was the problem!!!
finally everything was resolved, with extreme ease and speed
Thanks again
