ProjeQtOr free project management software - Track developments - Page 2 - ProjeQtOr
Track developments
26 Sep 2011 14:53 - 27 Sep 2011 12:29 #7 by JCDe
Replied by JCDe on topic RE : Track developments
Bug:
- Connection with profile "Project Leader" => schedule does not appear, Ok with admin ?
improvement:
- Currently difficult to easily remove activity (liked by dependencies)
- If parent activity can copy operations "child"
Other possible changes:
- Select multiple activity or milestone before recording.
- Idem to add resources.
- Calculating critical path
- When the user did not record: Submit to save and continue the action requested.
- Add Export To Excel (same Export to PDF) with possibility d'export a lot of activity (project ?)
29 Sep 2011 18:16 #8 by babynus
Replied by babynus on topic RE : Track developments
Bug:
Could you give some precisions :
- Could you detail ""schedule does not appear" ?
- Is the project leader affected to projects ?
Remove of Activity with dependencies should not be easy.
If dependencies exist, then the activity has some kind of importance.
To easily remove an activity from view, just set it as cancelled (it will be closed)
I don't understand the request. Could you explain ?
- Calculating critical path.
Interesting idea. Registered as ticket #433.
Already suggested. Implementation difficult because of management of errors on save.
Interesting idea. Registered as ticket #434.
03 Oct 2011 14:29 #9 by JCDe
Sorry for the delay.
1) During my connection with the profile "CDP" I could not see the schedule "GANT" => Empty screen. For info, CDP was well assigned to the project
2) You can copy actvities but not a "parent activity "(with sub-activities)
3) When you plan the next version?
