ProjeQtOr free project management software - [SOLVED] [5.5.3] on a new project, there is no profil defined for ressource's allocation, no allocation possi - Page 2 - ProjeQtOr
13 Oct 2016 09:01 #7 by mvern
Hi Babynus,
I clear the cache on chrome, and make a try on IE but still the problem on both. I also make a try on DEMO on Chrome and can assign ressource with profil.
13 Oct 2016 09:09 #8 by babynus
Please post projeqtor log file
13 Oct 2016 09:18 #9 by mvern
13 Oct 2016 10:10 #10 by babynus
Yes, it helps a lot.
Your issue is due to the profile you created : you created it without a sort order value.
And this case is not taken into account.
So define an order for all your profiles will fix the issue.
We'll have a fix to avoid this issue.
13 Oct 2016 10:22 #11 by babynus
Fix is to replace line 143 in /tool/jsonList.php from
$lstPrf=$prf->getSqlElementsFromCriteria(null,false,"idle=0 and sortOrder>=".$prf->sortOrder,"sortOrder asc");
to
$lstPrf=$prf->getSqlElementsFromCriteria(null,false,"idle=0 and sortOrder>=".(($prf->sortOrder)?$prf->sortOrder:'0'),"sortOrder asc");
14 Oct 2016 14:27 #12 by mvern
Hi Babynus,
Admin made the changes, and now profile is correctly set but I have a notification message "invalid control / you don't have the rights to create this element" after validation of ressource allocation. No error in logs
