ProjeQtOr free project management software - Cannot deleted ressource assigned in projet and delete project with 0 hours - ProjeQtOr
16 Mar 2017 22:20 #1 by chriscool
My project contains no activity no time allocation
I can not delete it
And I can not delete the assigned resources even as an administrator
What protection is blocking this?
We must remove the resources from the project and possibly remove it
Thank you for your help
17 Mar 2017 07:54 - 17 Mar 2017 08:02 #2 by diri
Looks like a coding problem:
Something is Null, is empty, is 0.
This has to be distinguished by code to get result being expected. Discovered it at several places.
You are also in trouble when trying to add something (be it action, task, project, ...) and you must break for some reason. Many times you must clear all input to be able to leave mask.
Last edit: 17 Mar 2017 08:02 by diri.
17 Mar 2017 10:29 #3 by babynus
It seems to be an access right issue.
Did you change something in habilitation configuration ?
17 Mar 2017 11:07 #4 by diri
@babynus
chris@mccool.fr wrote: I can not delete it
Even when system message points to habilitations (permissions) an administrator has to have permission to delete a resource (AFAIR it's default as well).
Due to several actions being impossible while testing the app I encountered multiple problems being related to issue mentioned before even when first pointer directed to habilitation.
17 Mar 2017 17:15 #5 by babynus
It repeat my question : "Did you change something in habilitation configuration ?"
In default configuration, administrator has capacity to delete project.
But habilitations can be changed, even for admin.
Moreover, if admin is allocated to the project with anoter profile, he may loose hability to delete project !
18 Mar 2017 12:46 #6 by chriscool
