ProjeQtOr free project management software - [SOLVED] installation ovh - ProjeQtOr
24 Jul 2017 14:38 #1 by pit
installation ovh was created by pit
bonjour,
je souhaite installer projeqtor chez ovh. J'ai donc 3 variables ovh :
Nom d'utilisateur
Nom de la base
Adresse du serveur
A quelles lignes correspondent ces variables dans la procédure d'installation ? (configure ProjeQtOr at first run)
tout est au vert sauf :
SQLSTATE[HY000] [2003] Can't connect to MySQL server on '127.0.0.1' (111) dsn = mysql:host=127.0.0.1;port=3306
merci.
24 Jul 2017 14:44 #2 by babynus
Replied by babynus on topic installation ovh
You did not read the forum rules.
Please do !
24 Jul 2017 14:47 #3 by pit
Replied by pit on topic installation ovh
I want to install projeqtor at ovh. So I have 4 variables ovh:
username
Name of the database
Server Address
Login password
Which lines correspond to these variables in the installation procedure? (Configure ProjeQtOr at first run)
Everything is green except:
SQLSTATE [HY000] [2003] Can not connect to MySQL server on '127.0.0.1' (111) dsn = mysql: host = 127.0.0.1; port = 3306
thank you.
24 Jul 2017 15:40 #4 by babynus
You must enter value in the database access parameters.
24 Jul 2017 15:45 #5 by pit
Yes but which ones? (Attached file)
Can you name them because too much option to understand in a language that is not mine ... just these 4 values and I manage ..
24 Jul 2017 16:03 #6 by babynus
Database host = 127.0.0.1 or localhost or Server Address
Database user to connect = username
Database password for user = Login password
Database schema name = Name of the database
