ProjeQtOr free project management software - Export to pdf doesn't work in reports - ProjeQtOr
12 Mar 2018 14:15 #1 by ED22
I modified an existing report, added new parameters, and new fields on displaying the results, but now the button Export to Pdf doesn't work. The file Print works. Here is the log file.
2018-03-12 13:03:06.144 ===== TRACE ===== DISCONNECTED USER 'admin'
2018-03-12 13:03:29.423 ***** ERROR ***** [V6.3.0] EXCEPTION *****
2018-03-12 13:03:29.428 ***** ERROR ***** [V6.3.0] on file 'C:\xampp\htdocs\projeqtor\external\html2pdf\_class\parsingHtml.class.php' at line (118)
2018-03-12 13:03:29.432 ***** ERROR ***** [V6.3.0] cause = ERROR n°4 : HTML code invalid, the tags are not closed in an orderly fashion.Status : Array
[0] => page
[1] => table
[2] => tr
[3] => tr
HTML : ...style="width:20%;">2</td><tr></table></page>...
2018-03-12 13:03:29.437 ***** ERROR ***** [V6.3.0] => #0 C:\xampp\htdocs\projeqtor\external\html2pdf\html2pdf.class.php (436) -> parse()
2018-03-12 13:03:29.441 ***** ERROR ***** [V6.3.0] => #1 C:\xampp\htdocs\projeqtor\view\print.php (239) -> writeHTML()
2018-03-12 13:03:29.445 ***** ERROR ***** [V6.3.0] => #2 C:\xampp\htdocs\projeqtor\view\print.php (183) -> finalizePrint()
12 Mar 2018 14:29 #2 by babynus
Error is clear :
You did not correctly open / close some tags
12 Mar 2018 14:34 #3 by ED22
I got that, but the problem is that with other reports it works, but with this one no. And I wanted to know if it had something to do with the fact that i changed some parameters and other things on this report
12 Mar 2018 20:29 #4 by babynus
Yes, you have to fix the issue you introduced...
Check you html result : some tags are not correctly closed.
