ProjeQtOr free project management software - Default Mask of Project - ProjeQtOr
22 Jan 2019 17:10 #1 by leader93
Is it possible to define a default mask for all user about list of Project.
For example, i want to show ID, WBS, Project Name, Type, Project Code, Name of the client, Status, situation, and several fields added
I found how to personalize for my profil but i want to have this view for all user (personalized view and not standard view).
Thank you in advance for your return
22 Jan 2019 17:20 #2 by babynus
Replied by babynus on topic Default Mask of Project
No, not without changing code.
You could change $_layout on ProjectMain.php, but this will be overwritten at each new version.
22 Jan 2019 17:23 #3 by leader93
Replied by leader93 on topic Default Mask of Project
Ok Thank you, i will try
