ProjeQtOr free project management software - problem with send mail - ProjeQtOr
23 Jul 2013 00:24 #1 by timoumi
I try to send mail to users with the 3.3.2 and 3.4.0 versions, but ther's no mail sender. I try with private smtp for my society and gmail smtp but no result. please help by example
23 Jul 2013 09:23 #2 by climb4fun
Replied by climb4fun on topic problem with send mail
Hi timoumi,
have a look at manual - global parameters - page 4 and 5. This should help. If not, please don't hesitate to come back to this forum.
Klaus
19 Feb 2014 20:02 #3 by netvienna
Hello I struggled with sendmail on Ubuntu and was nearly to give up :(
So if you use an external smpt for sending, here is the easy solution.
On Ubuntu sendmail configuration is extremely difficult with an external smtp.
It is much easier with ssmtp.
Install ssmtp and your live is much easier B)
www.havetheknowhow.com/Configure-the-server/Install-ssmtp.html
06 Oct 2014 10:52 #4 by simongrow250
Thanks for sharing.. :)
Yes, it's true. It is much easier with ssmtp. I already install it :) :)
09 Oct 2014 04:07 #5 by huynq8
Replied by huynq8 on topic problem with send mail
I using version 3.2.2 and tried but i not run
email of administrator: This email address is being protected from spambots. You need JavaScript enabled to view it.
'from' email when sending ...: This email address is being protected from spambots. You need JavaScript enabled to view it.
'reply' email when sending ...: This email address is being protected from spambots. You need JavaScript enabled to view it.
smtp server: smtp.gmail.com
smpt port: 587
.... (on version 3.2.2 don't have smtp login name or smpt login password)
Someone help me? Many thanks !
09 Oct 2014 12:01 #6 by babynus
Replied by babynus on topic problem with send mail
Gmail SMTP server requires authentication.
This functionality has been introduced in V3.4.
So concider upgrading ...
