ProjeQtOr free project management software - Installation - ProjeQtOr
Installation
15 Apr 2015 11:48 #1 by Fox-Johnson
Installation was created by Fox-Johnson
Hi
I cannot get past the main.php without receiving a 500 page
I have created a mysql database and altered the parameters.php file to the respective entries but I continue to get first the whirl and then the 500 message
The server is apache on linux
15 Apr 2015 15:59 #2 by babynus
Replied by babynus on topic Installation
Wich step are you in the setup process :
- did you fill in Configuration form ?
- did you log-in once (with database upgrade)
In other words :
- do you have a file nmae /tool/parametersLocation.php ?
- is the database full with tables ?
16 Apr 2015 12:43 #3 by Fox-Johnson
Replied by Fox-Johnson on topic Installation
Hi
Many thanks for the reply
I didn't get as far as the config form - just the opening page and the whirling circle then the 500 page
16 Apr 2015 13:40 #4 by babynus
So, if you did not reach the config form, which parameters.php file did you change ?
(the content and location of this file is defined in the config screen)
If you did not reach config screen, then you must must not have /tool/parametersLocation.php file.
Do you confirm ?
In this case, ProjeQtOr log file is not defined yet. You must check for errors in the apache log file.
Please check it and report any issue here.
16 Apr 2015 17:27 #5 by Fox-Johnson
Hi
Many thanks
I tried the projects/ again using FireFox again and to my surprise I got the config page so I filled out that which I wanted and pressed the OK button it whirled the wheel but then stopped - I can go no further.
So I created the parametersLocation.php file and placed it in tool as per the manual and tried again but it stops on the OK button - continue button does not appear
No 500 file so we have progressed!
16 Apr 2015 17:31 #6 by Fox-Johnson
Further to the above I went back to Safari and tried again and this time I got
*** ERROR ****
parameter file not found at 'parameters.php'
Check file '/tool/parametersLocation.php' or remove it to use '/tool/parameters.php'.
If problem persists, you may get some help at the forum at ProjeQtOr web site .
the parameters.php file is still in the tool folder
