ProjeQtOr free project management software - Installation - Page 2 - ProjeQtOr
Installation
17 Apr 2015 15:57 #7 by babynus
Replied by babynus on topic Installation
You should not have created parametersLocation.php file yourself.
You'd better let ProjeQtOr do it for you.
Once again, you should have a look at Apache log files : if possibly will give you hint about issue.
Now, from what I read, I suspect a write access issue : possibly the PHP user has no write acces to /tool folder or to other target folders.
To check this, try a brand new installation (without parametersLocation.php file created nor any manual change) and give full access to all folders and subfolders (for intance, in the web document root , try a "chmod -R 777 projeqtor")
This will let you have a clean install.
You'll be able to restrict access rights to folders afterwards.
21 Apr 2015 10:56 #8 by Fox-Johnson
Replied by Fox-Johnson on topic Installation
Hi
Thank you for your reply
I deleted the location file and reinstalled the clean parameters file - changed ti permissions to 777
No go - Internal Error messgaes
Replaced the parameters.php with the altered addresses etc for my own created dbs and bingo the view/main.php appears with the configuration page
Press OK - the whirl of the circle and then no further
Changed the fields on the form to reflect the parameters.php file but the same occurs
It Whirls and goes and we go no further
21 Apr 2015 15:38 #9 by babynus
For first install, you don't need a parameters.php file : it will be created during config.
What did you send permission to ? file or folder ?
You should apply it recusively to main projector folder.
What are these errors ?
Please report them here (or join apache or php log file)
You should not do this for configuration.
21 Apr 2015 16:48 #10 by Fox-Johnson
Hi
Many Thanks for your reply - I took out the parameters file
The 777 permissions were only applied to the projector file
Tried again and...
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, This email address is being protected from spambots. You need JavaScript enabled to view it. and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
The same as before.
Also I have checked and
No parameters.php file has been created
The only way I can get the configuration file up is as above by installing the parameters file and:
"Replaced the parameters.php with the altered addresses etc for my own created dbs and bingo the view/main.php appears with the configuration page"
21 Apr 2015 17:43 #11 by babynus
Normal, you did not get to the point where it is created (after config screen).
This will not help because you have a misconfiguration in your PHP setup that will prevent ProjeQtOr from working correctly.
Please find PHP log file and Apache log file and report them here.
