ProjeQtOr free project management software - send mail not work after upgrade to V5.0.0 - ProjeQtOr
17 Jun 2015 16:46 #1 by anisdz2015
can you plz help me to solve this, email notifications not work after projeqtor upgraded to V5.0.0 ...
LOG:
2015-06-17 14:06:18.264 ***** ERROR ***** ERROR *****
2015-06-17 14:06:18.264 ***** ERROR ***** on file '/var/www/html/projeqtor/external/PHPMailer/class.smtp.php' at line (803)
2015-06-17 14:06:18.264 ***** ERROR ***** cause = fwrite(): send of 16 bytes failed with errno=32 Broken pipe
2015-06-17 14:06:18.265 ***** ERROR ***** Error sending mail
2015-06-17 14:06:18.265 ***** ERROR ***** SMTP Server : mail.xxxxx.dn
2015-06-17 14:06:18.265 ***** ERROR ***** SMTP Port : 587
2015-06-17 14:06:18.265 ***** ERROR ***** Mail stored in Database : #648
2015-06-17 14:06:18.265 ***** ERROR ***** PHPMail error : SMTP connect() failed.
2015-06-17 14:06:18.265 ***** ERROR ***** PHPMail debug :
17 Jun 2015 17:15 - 17 Jun 2015 17:16 #2 by anisdz2015
Log = 8
2015-06-17 16:10:57.261 ***** ERROR ***** ERROR *****
2015-06-17 16:10:57.261 ***** ERROR ***** on file '/var/www/html/projeqtor/external/PHPMailer/class.smtp.php' at line (218)
2015-06-17 16:10:57.261 ***** ERROR ***** cause = stream_socket_client(): SSL operation failed with code 1. OpenSSL Error messages:
error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol
2015-06-17 16:10:57.261 ***** ERROR ***** cause = stream_socket_client(): Failed to enable crypto
2015-06-17 16:10:57.261 ***** ERROR ***** cause = stream_socket_client(): unable to connect to ssl://mail.xxxx.dn:587 (Unknown error)
2015-06-17 16:10:57.262 ***** ERROR ***** Error sending mail
2015-06-17 16:10:57.262 ***** ERROR ***** SMTP Server : ssl://mail.xxxx.dn
2015-06-17 16:10:57.262 ***** ERROR ***** SMTP Port : 587
2015-06-17 16:10:57.262 ***** ERROR ***** Mail stored in Database : #660
2015-06-17 16:10:57.262 ***** ERROR ***** PHPMail error : SMTP connect() failed.
2015-06-17 16:10:57.262 ***** ERROR ***** PHPMail debug :
Last edit: 17 Jun 2015 17:16 by anisdz2015.
17 Jun 2015 17:27 #3 by babynus
It seems OpenSSL is not enabled on your PHP server.
Could you check ?
17 Jun 2015 17:44 #4 by anisdz2015
how to check it can you give commande or file to check
17 Jun 2015 17:47 #5 by anisdz2015
#php -i |grep -A 5 openssl
résultat:
openssl
OpenSSL support => enabled
OpenSSL Library Version => OpenSSL 1.0.1e-fips 11 Feb 2013
OpenSSL Header Version => OpenSSL 1.0.1e-fips 11 Feb 2013
17 Jun 2015 18:04 #6 by babynus
Strange...
From wich version did you migrate ?
(there was no change on V5 on this side)
