ProjeQtOr free project management software - Issue with resource names while importing - ProjeQtOr
06 Oct 2015 14:50 #1 by iqbal.ahmed
Hi
I am trying to import MS Project file to ProjeQtOr using "MSProject to Projeqtor - Activity Import -DSM Community"
I have downloaded the manual "MSProjectToProjeqtor-ActivityImport-Manual-English-Community" and implement the all steps.
The issue:-
1). after importing successfully, resources were not imported if there is mire one name / if there is one resource it will imported.
2). Can I split effort of one activity e.g. : resource A= 3h and resource B=5 ?
3).I have noted effort unit is "day" can I change it to "hour"
4). I have attached "MSProject to Projeqtor - Activity Import - Community_test"
Can you please support.
Thank you.
06 Oct 2015 15:05 #2 by babynus
I will try to answer questions I can answer, but as I did not design this tool, my knoledge is limited.
Maybe you should create resources in PRojeQtOr first. Not so long and should be more easy.
You can in ProjeQtOr. Don't know if import tool enables it.
Yes, you can parameter this in global parameters.
But you should always import as days (as it is unti used to store data)
Hope this helps.
06 Oct 2015 17:45 #3 by iqbal.ahmed
I have already created the resources in ProjeQtOr but not able to import the resources
Di you know who created the tool "MSProject to Projeqtor - Activity Import - Community_test" can I contact him for support?
Thank you.
06 Oct 2015 18:17 #4 by babynus
Contributor is francis2301 on the forum.
He may reply to your post if he has time.
