ProjeQtOr free project management software - Load of a resource is not counted in the calculation - ProjeQtOr
17 Jan 2019 11:38 #1 by timshel
The load of a resource is not counted in the calculation and the different views (planning, global planning, reports, ...). Version 7.3.3.
See example in attachment.
17 Jan 2019 17:02 #2 by babynus
You just diudn't run planning calculation, that will update planned dates.
18 Jan 2019 12:00 #3 by timshel
It's exactly what I did but same problem.
I also validate the planning.
I haven't got any scheduled date in the task. Validate date (start and end) are inserted.
20 Jan 2019 14:25 #4 by babynus
I guess you used "Administrative " for project type.
Administrative projects are not planned, there are used to store "out of duty" work (holidays, hillness, ...)
21 Jan 2019 11:08 #5 by timshel
This is not an administrative project but an internal project.
21 Jan 2019 11:19 #6 by babynus
Just to be sure your project is calculated : change something on allocation of a task (left work for instance).
The icon of the project should change : get an orange center.
Then calculate planning : does icon of project is still with orange center or does it go back to normal white center ?
